SLK-Class (R170) 1998-2003: SLK 200, SLK 230K, SLK 320
SLK/R170: Dashboard side indicators not working
Old Jun 10, 2019 | 08:38 AM
tzimis0tigris's Avatar
SLK 200 KOMPRESSOR
I have recently bought an SLK 200 r170 ( 2001), and there is no sign from dashboard side indicators left & right BATTERY, HANDBRAKE, CHECK ENGINE etc. it is always turned off, black.
Is there any advice on which direction I should start the investigation first?
Old Jun 20, 2019 | 03:36 PM
khomer2's Avatar
02w163ML500 / 97w210E50AMG / 99w202C230k / 95w124500e-wip
Welcome tzimis0tigris,
Simple things first.
1) Fuses.
2) Loose cable connection to the instrument cluster. There are plenty of how-tos on removing the cluster to check the connections on the backside, etc.
Use the search feature to find a read thru the pertinent posts on how-to.
Old Jun 21, 2019 | 08:57 AM
SLK 200 KOMPRESSOR
Thank you khomer2 for your reply, I’ve removed the instrument cluster to find out that the previous owner had black-taped from the inside the symbol panels so no indicator was visible. I can’t imagine for what reason he did that but anyways the problem is solved.
