SLK-Class (R170) 1998-2003: SLK 200, SLK 230K, SLK 320
SLK/R170: Changing Gauges
Old Aug 19, 2004 | 10:35 AM
NJspeed69's Avatar
Changing Gauges
I need to replace the gauges in my SLK, as my gas gauge no longer works. Heres my replacement.
What I need to know is whether this is an easy swap and if it changes anything, such as the mileage. It's a digital readout so you'd think it would be an easy swap, but I really don't know. Any help is appreciated.
Old Aug 19, 2004 | 04:20 PM
Kirill's Avatar
SLK 320
You sure that it is fuel gauge that broke and not the sender unit in the gas tank ?
Old Aug 19, 2004 | 05:00 PM
2SEATR's Avatar
When you connect the new cluster, the mileage on your replacement speedometer/odometer will be displayed.
You have the choice of swapping your old speedometer/odometer to the new cluster, or going to a speedometer repair shop who can re-calibrate the new odometer to your old one.
Removal of the cluster is not too difficult. The steering wheel does not have to be removed.
