SLK-Class (R170) 1998-2003: SLK 200, SLK 230K, SLK 320
SLK/R170: slk320 manual
Old Apr 23, 2021 | 03:44 PM
phil alvirez's Avatar
2005 chrysler crossfire
slk320 manual
am experiencing hard shifting-especially with the 2nd gear. i have been suggested to get a replacement of the shift selector cable.
can anybody provide a link where to find it?
thanks
in the diagram, is item #1 https://www.moparpartsgiant.com/part...t_control.html
Old Jul 9, 2021 | 10:29 PM
beeguz's Avatar
2001 SLK 2017 Chevy Bolt, 2019 Subaru Crosstrek
You might try finding new bushings or shimming the bushings with thin flat washers, it might take enough play out of the cable to make it a bit easier to shift.
I couldn't find any new parts on line, but you may be able to find a used cable if the shims do not do the job for you.
Perhaps the aftermarket has a shifter that will work?
