SLK-Class (R171) 2004-2010: SLK200K, SLK280, SLK350, SLK55, SLK55 Black Series
SLK/R171: SLK 320 Diesel V6 Triple turbo
Old Mar 4, 2005 | 08:46 AM
jono_2000's Avatar
taken from http://www.germancarfans.com/news.cf...id/2050303.010
are these references to production cars??
The direction in which the engineers at Mercedes-Benz are taking compression ignition engines is being shown in Geneva by the two diesel-powered roadsters that boast record performance figures. A new V8 engine generates 231 kW/315 hp in the Vision SL 400 CDI and provides the eight-cylinder’s crankshaft with an outstanding torque of 730 Nm. The SLK 320 CDI tri-turbo, meanwhile, can generate an impressive 210 kW/286 hp and 630 Nm of torque from three litres of displacement (70.3 kW and 211 Nm per litre of displacement).
Three turbochargers in the SLK-Class
The SLK 320 CDI tri-turbo is based on the new V6 diesel engine, which achieves new levels of performance thanks to a two-stage supercharging system. It consists of three turbochargers, of which two are located on the outside next to the cylinder banks while the larger third turbocharger is situated between the V of the cylinders. At low engine speeds and loads, air flows through all three turbochargers (i.e., large and small), with the small turbochargers doing most of the work. When engine speed increases and the flow is continuous, the large turbocharger takes over supplying the greatest share of the charge pressure and the smaller turbochargers are turned off by means of a bypass system. At high engine speeds and loads, only the large turbocharger is running. Performance is further heightened as a result of an enlarged intercooler and larger pipe diameters for the charge air and the exhaust.
Sporting a modified tachometer with a red zone extending from 4,500 to 5,000 rpm and the self-confident appearance of the SLK 55 AMG, the vehicle is a proud member of the Mercedes-Benz diesel family. The new engine gives the roadster an impressive boost and allows it to perform prodigious feats: It takes the car but 5.3 seconds to accelerate from 0 to 100 km/h, and it can travel a distance of 1,000 metres in just 24.4 seconds from a standing start. The top speed is meanwhile electronically limited to 250 km/h. With this kind of performance, the SLK 320 CDI tri-turbo has a unique standing even among thoroughbred sports cars. And fuel economy is just as impressive, since, despite the incredible driving performance, the diesel roadster consumes only 7.5 litres of fuel per 100 kilometres (NEDC overall consumption).
Old Mar 4, 2005 | 03:49 PM
evanichka's Avatar
2005 SLK350
https://mbworld.org/forums/slk-class-r171/99885-slk-320-cdi-triturbo.html
