SLK/R171: Malfunction Warning after installing Smoked Tailights
'05 SLK350
I just had my bodyshop install the smoked tailights I received from R171.co.
Everything and all the bulbs are working, however on the on-board computer, there is a warning prompting that there is a malfunction on the rear lamps.
I checked the bulbs from the stock lamps and everything is the same. The installation was also a direct plug in so I don't know what the problem is.
Any of you with similar experiences or know of a cure?
Thanks in advance.
Thanks in advance.
is the plug that goes into the lights attached to each light itself or is there a seperate bit with the bulbs? i assume the latter
and if so, why not just use the current light board you had with your first lights?
Zishan
Zishan
