SLK/R171: Break In
I was told not to use cruise control for first 600 miles and not to go over 100mph for first 1000 miles (which i wouldnt do anyways)
Also, they say you need oil changes once every 13k miles! What have you guys heard about this?
not rev above 3500rpm
not go over 100km/h
this was for the first 1500km.
but usually i break all the rules within 200km. can't help it if i've got lead foot.
And yeah, 13000 miles, give or take. It will tell you when it's time to change, and it will auto-adjust to your driving style. You can cycle under the mileage menu in the instrument cluster for your distance to service.
don't baby the engine...that's NOT good for it. By babying, I mean, keeping it under 3k all the time, not opening it up once in a while, etc. If you do baby it, the piston rings will NOT seal properly, which results in increased oil consumption and poor fuel economy down the road. As you baby the engine, the rings do not know the higher engine speeds, so it's acustomed to the lower engine speeds...therefore when you cross the 1000 "break-in" period and open it up, the rings are not use to that.
Best thing to do is vary your speeds, don't keep it at one set speed, e.g. 55mph on the highway. But don't go redlining it every redlight either. Vary the RPM band, open it up once in a while. Drive it as you normally would with other cars except lay back on the WOT (wide open throttle) if you do so. That's the best way to break in your engine. This way, the rings will seal and seat correctly and lead to many happy motoring miles
Have fun
Operation
The first 1000 miles
The more cautiously you treat your vehicle during the break-in period, the more satisfied you will be with its performance later on.
- During this period, avoid heavy loads (full throttle driving) and excessive engine speeds (no more than 2/3 of maximum rpm in each gear).
- Do not attempt to slow the vehicle down by shifting to a lower gear using the gear selector lever.
- Shift gears in a timely manner.
- Avoid accelerating by kickdown.
- Select positions 3, 2, or 1 only driving at moderate speeds (for hill driving).
- Select C as the preferred shift program for the first 1000 miles.
Additional instructions for SLK 55 AMG:
- During this period, avoid engine speeds above 4500 rpm in each gear.
It didn't get driven for two more months,(Jan & Feb) actually, while my wife was advertising (and finally sold) her '98 SLK230 (got $18.8K on eBay).
Anyways..., when starting up the new SLK350, it would "puff" oil smoke for the first two seconds... I assume some oil which had collected in the cylinders between bi-weekly "battery-charging" sessions.
Now that its got 600 miles of city/hwy driving, I don't think that the "oil smoke starts" are happening anymore, with the break-in continuing...
Will keep an update on this, and watch oil consumption over the first 3000 miles...
