SLK-Class (R171) 2004-2010: SLK200K, SLK280, SLK350, SLK55, SLK55 Black Series
SLK/R171: Door Mirror housing removal?
Old Jun 25, 2005 | 07:55 AM
Sorcerer's Avatar
SLK 350
Hi,
Does anyone have any info, PDFs on removal of the mirror housings?
Mike
Old Jun 25, 2005 | 12:29 PM
Maverick's Avatar
2005 SLK350, Mars Red - Tan Interiors
I have no idea how, but may I ask why you want to? I have noticed that the clear turn signal lens on one of my door mirror housings fogs up when I wash the car. The other one does not. I think there must be a weather seal that is defective, and I am going to let the dealer take care of it next time I take it in. But I was wondering if that might be the reason you are looking to remove your housings?
Old Jun 25, 2005 | 12:39 PM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
One of the reasons could/would be because it makes it easier to install the convex EURO mirrors which some believe (I'm one of them ) are better because they have a built-in angle which helps eliminate/improve the blind spot inherent to the US style mirrors.
Old Jun 25, 2005 | 02:38 PM
Sorcerer's Avatar
SLK 350
I want to fit this Chrome housing:
I haven't had a proper look yet, I suspect that trim from inside will need to be removed first.
Mike
Old Jun 25, 2005 | 08:58 PM
bloflin's Avatar
2005 SLK55 AMG
Mike
Mike, I'm not positive on the chrome mirrors, but on most of the rest of the chrome stuff it sticks on, on top of the current, you don't need to remove anything.
Old Jun 26, 2005 | 05:44 AM
Sorcerer's Avatar
SLK 350
Hi,
The original Mercedes accessory replaces the existing housing, much better than non Mercedes stick on covers.
Old Jun 26, 2005 | 07:40 AM
MBenzNL's Avatar
Former Vendor of MBWorld
some slow@$$diesels
take the mirror glass out...be carefull with the cheap@$$ pass sider glass as that one will most likely crack and unless your driverside is an auto dimming glass, it will want to crack during removal as well.
take the torx10 screws out that hold the cover...take the mirror motor out...take the cover off.
greetingz,
Old Jun 26, 2005 | 08:07 AM
Sorcerer's Avatar
SLK 350
greetingz,
Thanks for that - I will wait for a hot day, you can see where the mirror is clipped in if you adjust it to one extreme or the other.
