SLK-Class (R171) 2004-2010: SLK200K, SLK280, SLK350, SLK55, SLK55 Black Series
SLK/R171: SLK350 and Nibble Antenna
Old 05-23-2006, 02:59 PM
Tooxzist's Avatar
Question
Does anybody know where I can get the SL 500 stub antennae for a good price?
I think the part number is: 230-827-0101
I'm not sure if the year matters on the SL (between 03 - 05) but if it does then please let me know.
I like the SL look and am willing to sacrifice radio reception and key fob range for the hott look. Besides it comes painted in oem color too.
Any help would be appreciated.
Thanks.
2005 slk 350
Black
Old 05-23-2006, 03:29 PM
etyu's Avatar
2008 SLK 55
Smile
Originally Posted by 9moon
neither can i.. but anyhow, where is that tool hidden? is it w/ the rest of the tools that came w/ the benz? i dont remember seeing any tool similar to that..
Sorry. try: www.benzworld.org and go to R171 forum. In the R171 forum, go to page 13 on the top row menu. In page 13 the topic is: Need help with SLK antenna! How to remove?
The black round tool came in a small plastic package with the owner's manual, first aid kit, and cloth windscreen. If not you can purchase from the local MB dealer at their parts section (should be relatively inexpensive).
"Does anybody know where I can get the SL 500 stub antennae for a good price?
I think the part number is: 230 827 01 01."
The SL antenna sells for around $100 from the dealer and your RF range will be reduced to about 30 - 35 feet. There is a 9xxx following the above part no. to designate the color code (last 3 digits, e.g., pewter or cubanite silber will be 9723).
Old 03-04-2007, 06:21 PM
Modbug's Avatar
Bringing this thread back to life...
I've personally installed the R170 (w/ ridges) short antenna, and reception has definitely been affected. There is more static in general, and when you drive further away from the "hotspot" of your local favorite radio station, it worsens. Just so you folks understand where I'm coming from, I commute from San Francisco to San Jose and vice versa and I toggle between 106.1 and 94.9 and 103.1
In addition, when you enter a garage complex or dense/building-centric area, the static is also very evident. There is also a tendency for the radio to receive mixed signals from close-frequency stations.
I've also tried the SL-antenna. Reception is even worse than the R170...so I'd definitely stay away.
I just ordered the full SL-radio kit and will post up again when it's installed. Hopefully, that one works a lot better than the two I've tried thus far.
Old 03-16-2007, 09:03 PM
MojitoLoco's Avatar
2007 Diamond Silver SLK 280
Here are some photos from my install; took about 5 minutes. Note the antenna tool does not come with the R170 antenna, it came with the car. The silver metal tool is from my tool box, basically you just need to make a lever of sort to turn the tool.
Attached Thumbnails SLK350 and Nibble Antenna-view_1.jpg   SLK350 and Nibble Antenna-view_2.jpg   SLK350 and Nibble Antenna-antenna_tool.jpg   SLK350 and Nibble Antenna-remove_antenna.jpg
Old 03-17-2007, 10:28 AM
Ynot's Avatar
MBZ SLK
Paint it, it'll look so much better.
Old 03-17-2007, 03:49 PM
lorinser_komp's Avatar
05 Lorinser C230 Komp SS, 02 C230 Komp Coupe
I dont like the antenna. I am gettin me an R171 in a month or so, I am going to have the body shop shave the antenna off.
Old 03-17-2007, 08:26 PM
  #32
MojitoLoco's Avatar
Is yours painted a matte silver?
Old 03-17-2007, 09:17 PM
  #33
Ynot's Avatar
MBZ SLK
No, Iridium silver just like my car, even has the metallic flakes.
Old 03-31-2007, 03:21 PM
  #34
JimmyJ1's Avatar
SLK 359 Designo Mocha
Has anyone looked into an electric antenna that retracts when not in use?
Jimmy.
Old 03-31-2007, 06:06 PM
  #35
Ynot's Avatar
MBZ SLK
Jimmy.
No, why, those are so 80's. why would you want something like that
Old 04-01-2007, 04:31 AM
  #36
JimmyJ1's Avatar
So I can put the cover on the car.
Old 04-02-2007, 12:29 AM
  #37
Ynot's Avatar
MBZ SLK
Just twist it off, takes a few seconds.
Quick Reply: SLK/R171: SLK350 and Nibble Antenna
