SLK/R171: springs...
You should check them out since they are so close to you. Maybe have them fit my wheels on your car to make sure it fits properly before they send it back. Do they still have your wheels over at DCR? I might drop by and try them on
I really like the Catalunya style rim, but with all these issues about rubbing and dropping, i'm a little worried. I remember you recommending 19x9.5 in the back instead of 19x10. Is there a reason? To prevent rubbing I'm assuming. Are there any drawbacks to having 255 in the back compared with 265?
Catalunya style are really nice, I like that style as well. I wouldn't worry about it too much, many members had their problems resolved, since I was the guinea pig for DCR, you should not have a problem. The problem with my car was they did not have a SLK to get the right measurements, since you reside in SoCal it should not be a problem.
Yes, the reason for 9.5" out rear is b/c of more rubber protecting your wheels. The max tire width is 265 rears w/o modification and on 10", it's stretching the tires, no protection, you will see if you decided to try my wheels out. Just not worth the extra half inch, it doesn't benefit from it unless you can fit 285 in the rear.
More width, more traction/grip. plus 255 width is very hard to find, 265 is pretty standard so, you can pick up a set alot easier than you can with 255. 255 will still be better than the stock 245's.
I am thinking of lowering my SLK by just chaning the springs. Will it give me a harsh ride just by doing so? And I have notice that concern about tyre rubbing issues. Will I have the same problem if I am just using 18 inches AMG spec wheels?
Thanks in Advance
Thanks in Advance
No, you probably will not have any issues if they are 18" AMG spec wheels, it's the aftermarket wheels you should be worry about but I think the SLK has been around long enough for them to get the proper measurements. So rubbing should not be an issue.
