SLK/R171: Uneven tire wear after lowered
Have any of you guys with lowered cars experienced uneven tire wear? I was reading on another forum were one guy has tire wear issues on the inside of his front tires after lowering his vehicle. If so, how can this issue be resolved? I have ordered HR springs and installing them soon so if there are any issues/work arounds please let me know. TIA
190D 2.5 (x2), 190E 2.6, W202 C240,W202 C43 (C55), W210 E55, W212 E250CDI
Did you have a wheel alignment after you lowered the car initially?
If not then that is you're most likely cause. Lowering it changes the camber and toe which can increase tyre wear
MBZ SLK
Correct, get an alignment first then try checking your tire pressure.
Read this thread, it may help
http://www.benzworld.org/forums/r171...res-temps.html
Thanks and just an fyi... I just spoke with my dealership and I was informed that any part that goes bad or is in question that touches an aftermarket part will void the warranty for that part. For a 1.2 inch drop on a car with an extended warranty and only 16k miles, I am too affraid to touch this!
MBZ SLK
2006 SLK280.
i ahd a wheel alignment doen after lowerinf my car to try and stop tyre wear, but had to go to dealer as MB don't release the settings to outside garages over here. wasn't dear tho, but a pain i had to make the trip to the dealer.
'12 C204 C250, '05 SLK350 (sold)
If you're doing an aftermarket drop, you don't need to go to the dealer. The alignment shop should know to eliminate toe in/toe out, adjust caster, adjust camber (perhaps a little negative in the fronts). That is the same with every car. I don't understand what's so special?
