SLK/R171: Slk63 Amg
BTW, i am on AMG private lounge and read the previous chat. I doubt anything will change this time around.
Germancar1,
obviously you have little experience with the SLK, and the other cars you consider sports cars. I'll bet you are going to say something like, 'slk 55 doesn't have manual transmission, therefore it's not a sportcar.' or some other narrow view point to use as your argument.
M
What people here don't get is that car companies don't like to talk about new models too far in advance for a variety of reasons. Main one being that the SLK55 had/has a while to go on the market.
BMW said that there wouldn't be a M version of the Z4, but sales didn't go according to planned an poof(!) there it was a M Z4.
M
So C43, what did you learn in affalterbach that indicates a R171 SLK 63? Don't give me that, 'i can't say for legal reasons' crap, you already put it out there, either you retract your statements, or you post what you learned. Otherwise you are just another BSer.
As far as finding a senior California member to hold the money - I'll give mine to a NJ moderator -RBrenton - he'll have it by mid-next week.
...come on man...you really don't want me to go there ..do you?
RE the R172 powerplant, it's definetely possible that there will be an SLK63, and i eagerly await it, but on the other hand, I and many other SLK 55 owners received a survey asking about our opinions on a supercharger or turbocharged engine, and whether or not having a v8 (regardless of power)was crucial to our decision to buy. To me that indicates they have already set a target HP, and will consider a turbocharged/supercharged v6 in place of a NA v8, since both will have similar power.
If you agree, i'd rather give my money to FrankW. I'll have to ask him, but i'm sure he won't mind.
M
A new chasis designed with those higher HP numbers in mind would be a different story.
Also, if the car was lighter, the tires wouldn't have to be so large to get the power down since a lighter object will have less counter friction against the kinetic energy needed to propel it forward. An Ariel Atom for example can be had with 300hp giving it a power to weight ratio much better then the SLK's, yet the tires are not all that big and it manages insane track times and 0-60 times of 2.7-2.9 seconds.
A cheap mod from Brabus or Kleemann does this. If they can do it, so can MB/AMG.
Once again, Kleemann owners say theirs is perfectly drivable.
Is it the tires? Once again, I say, lose weight and it could use 450 just fine. Or add slightly wider tires and it also helps. LSD helps even more. None of this is 'impossible' to add to an SLK, it's already being done for a couple thousand bucks by tuners.
I believe (and it's just my opinion), but the SLK could take those 450hp just fine, and it seems to be in the hands of some owners.
