SLK-Class (R171) 2004-2010: SLK200K, SLK280, SLK350, SLK55, SLK55 Black Series
SLK/R171: New member New owner New roof problem
Old Sep 27, 2014 | 01:26 AM
matty2332's Avatar
MB SLK
Hi,
In trying to solve my problem I stumbled across this wonderful and informative site
So I have a 10 year old SLK and up until today the vario roof has worked fine, now when i try to put the roof down to enjoy the last days of summer, it unlatches fine, folds away as usual but the boot (trunk) lid refuses to go down over the parked roof. At that point I have to close the roof when it latches back on the windscreen and the boot lid closes fine
Can anyone point me in the right direction.
Many thanks
Old Oct 15, 2014 | 10:46 AM
woolray's Avatar
SLK 200k & A Class
It could be the micro switch for the boot lid sticking or faulty
Old Oct 15, 2014 | 11:16 AM
Top Hydraulics's Avatar
SPONSOR
03 SL Kleemann, 97 SL320 pano top, 95 Lorinser E320 Cabrio, Ferrari 360, Tesla X
Originally Posted by matty2332
Hi,
Many thanks
matty2332,
welcome to the forum! I don't have an R171, nor have I worked on one yet, but maybe I can share some knowledge from the over 30 brands and hundreds of models that we rebuild and upgrade the hydraulic systems for.
When your Vario roof stops in the middle of a cycle, then you have an electrical or a hydraulic problem. In your case, it is almost certainly an electrical problem with a micro switch not signalling to the controller that it is okay to take the next step (i.e., close the trunk lid).
The trunk lid closes fine when you are closing (raising) the top, so what's the difference when the top is opening and the trunk lid won't close? I would guess that the computer is not getting the signal that the top is down in the storage area. I hope that someone can point out which micro switch indicates the top being retracted, or that you can find this out yourself and post a photo.
When diagnosing an electrical problem during the Vario roof opening or closing cycle, always put yourself into the position of the control module: it needs input that everything is safe and ready for the next step. If that input isn't there, then you will usually find the pump running without the computer giving a signal for the next valve or combination of valves to open and allow hydraulic fluid to pressurize the cylinder needed in the next step.
In some less common cases, the control module will shut down hydraulic system operation if the signals from the various micro switches seem illogical, but that's another story and it isn't the case here.
I hope this helps,
Klaus
www.tophydraulicsinc.com
http://www.tophydraulicsinc.com/en/4...lk-class-04-11
Old Oct 15, 2014 | 02:34 PM
matty2332's Avatar
MB SLK
Klaus & Woolray, thankyou for your response. I have now narrowed it down as you say to a faulty microswitch. I need to locate the switch that tells the ECU that the roof is parked in the boot so the boot lid can come down.
Old Oct 15, 2014 | 02:42 PM
woolray's Avatar
SLK 200k & A Class
Hi Matty2332
here is a link for lots of problems including Vario Roof.
www.billsden.org/mercedes/slk/docs
hope this is helpful.
Old May 25, 2015 | 01:13 PM
jnc1948's Avatar
2004 320slk
Help 2004 slk 320 91,000 miles...roof only come up half way ans stop any ideas why and what can I do about it?
jnc1948
