SLK-Class (R171) 2004-2010: SLK200K, SLK280, SLK350, SLK55, SLK55 Black Series
SLK/R171: 1999 SLK 230 Kompressor no acceleration. Please help!
Old 07-31-2017, 10:52 PM
Rcresendes's Avatar
1999 Mercedes-Benz SLK 230 Kompressor
No acceleration at all. I've replaced the TPS, throttle body, reset the fuel accerator switch, both with stepping on the accerator in the on position and also the in drive with foot on brake method. I've cleaned the mass air flow sensor. Here are some videos to show what I'm talking about. Please help.
https://youtu.be/SU2AN1fZWK4
https://youtu.be/zGAcZ9iyK9Q
At this point I'm thinking the ECM. But there are some sensors on the cam I'm not sure about. Not the cam position sensor. Something else. Can some one tell me what these two sensors are. The one on the right is getting blow back of oil.
Old 07-31-2017, 11:03 PM
ItalianJoe1's Avatar
2003 CL 600
I assume you're talking about the big round thing, that's the cam actuator solenoid, it controls the flow of oil into the cam gear to actuate the VVT.
Have you done any diagnostics aside from just replacing parts?
No acceleration at all is more likely a throttle problem than a sensor on the engine. Pedals fail, throttle bodies fail, could be many things. Proper diag will save you time/money.
Old 08-02-2017, 06:58 AM
Rcresendes's Avatar
Ordered the camshaft adjsuter. Lets see what that does.
Ordered the camshaft adjuster which is the sensor on the right. I read some forums on that so lets see what that does.
Old 08-02-2017, 07:02 AM
Rcresendes's Avatar
Diagnosis
I ran a scan on it from home with no codes at all. While running, everything comes up as normal on the scan tool. The only code on the dash is the BSR/ASR. But I removed that fuse while running and it made no difference. I replaced the Throttle position sensor and the throttle body with no difference. I ordered the camshaft actuator/adjuster. Not sure what else it could be besides a computer.
Old 08-07-2017, 05:37 PM
Rcresendes's Avatar
Update
I just replaced the camshaft adjuster/actuator amd still nothing. I even reset the fuel switch. Frustrating!!
Old 08-07-2017, 07:36 PM
2003 CL 600
This is not diagnostics...
What type of scanner are you using?
You need to understand why the system is failing before you try to fix it.
Old 08-07-2017, 07:44 PM
Rcresendes's Avatar
Diagnosis type
Old 06-12-2021, 05:05 PM
Kyle marcel's Avatar
Slk230
Slk 230
Hi im sorry to disturb u... ive seen ur post and I seem to have the same problem u had.... is there anychance u could direct me in the right direction.... my slk 230 wont accelerate an ive replaced the tps
Old 06-13-2021, 10:12 AM
Rcresendes's Avatar
ECU
I had to replace the ECU. Once I got the new computer, it was reprogrammed to the car and the issue went away.
Quick Reply: SLK/R171: 1999 SLK 230 Kompressor no acceleration. Please help!
