SLK-Class (R171) 2004-2010: SLK200K, SLK280, SLK350, SLK55, SLK55 Black Series
SLK/R171: OVERVOLTAGE at Terminal 30 SLK350
Old Nov 13, 2020 | 07:28 PM
racer88's Avatar
SLK350
Hello!
I'am new here but long time with my SLK350 - 2005 - Mine since new... now with only 17K miles.
Apperar code C1212 Overvoltage at Terminal 30 and others 7 codes. Disconect the ABS, BAS and ESP.
Someone can help me?
I found some informations for undervoltage but mine is overvolotage.
Thanks.
Old Nov 15, 2020 | 04:13 PM
racer88's Avatar
SLK350
VIN - WDBWK56F15F022895
Codes readed
C1212 - Overvoltage at terminal 30
C1510 - For this model series ignore the fault code
C1025 - Comunication with the engine system is faulty
C1027 - Fault in CAN comunication with control unit N15;3 (ETC/EGS) control unit
C1210 - 1 - road test 2 -terminal 30 undervoltage
C1123 - L6/3 - Rear Speed Sensor carry out visual inspection
C1122 - L6/3 - Left Rear speed sensor signal fault
C1707
I try to erase, the scan send the request, but when it check it again, the codes return... only with ign position 1, does not need to start engine.
Old Sep 25, 2021 | 01:20 AM
Russell Ormerod's Avatar
not a merc
Overvoltage =alternator regulator ! Simple as that
