SLK-Class (R172) 2011-Present SLK200, SLK250, SLK350, and SLK 55
Tachometer stopped!, why?
Old Jul 28, 2024 | 04:49 PM
Kaz. Hirasohzu's Avatar
SLK200
I have 2012 SLK200 R172.
The tachometer will stop after the needle sweep. Cay you Please help me.
It works during start-up sweep-up.
This meams it may be misconfiguration of
the data? if so which data?
The trouble started about six months ago when we worked on changing the torque limit.
If I can't solve it, I need to replace it with a used tachometer and make it recognized.
Please tell me the procedure as well.
Old Jul 28, 2024 | 08:38 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to R172 forum...
Old Mar 6, 2025 | 10:02 AM
Ronald Tang's Avatar
Hi~
My friend's SLK200 R172 had had the same fault, luckily I was able to locate the issue and fixed it yesterday.
I corrected the item "Tachometer (Technometer_mode)" from "Dynamic" to "Standard" by manual coding (offline coding) in the instrument cluster, then it works fine.
(The scan tool I used is in Chinese, so I translate the wording to English, the wording in your scan tool may vary.)
Hope that my experience can be your reference.
Old Mar 6, 2025 | 04:50 PM
W205C43PFL's Avatar
Originally Posted by Ronald Tang
Hi~
What scanner was that curious.
Old Mar 10, 2025 | 04:36 PM
SLK200
Hi! Ronald,
thank you for the message.
It's VERY kind of you because my tachometer has been stopped over 1 year.
I could not get any information about 8 months.
So,
I'll confirm the tachometer mode that you mentioned.
I appreciate your message.
Kazuhiko Hirasohzu
Originally Posted by Ronald Tang;[url=tel:9122959
9122959[/url]]Hi~
Old Mar 11, 2025 | 06:38 AM
It is a Launch X431 Pad V.
Old Mar 11, 2025 | 09:15 AM
W205C43PFL's Avatar
​​​​​​I see, thanks for the information.
Old Mar 11, 2025 | 11:23 PM
SLK200
Hi,
I got it. thank you!
Best regards,
Originally Posted by Ronald Tang;[url=tel:9125491
9125491[/url]]It is a Launch X431 Pad V.
Old Jun 7, 2025 | 01:34 PM
SLK200
SLK200 Tachometer trouble Fixed
Hi, Friend,
last Friday,
finally,
my Tachometer trouble was Fixed!
You are right!
So, key parameter is the mode parameter.
I did not need new meter assembly.
Thank you.
best regards and have a goodday.
Kaz. Hirasohzu.
Hi! Ronald,
So,
Kazuhiko Hirasohzu
Old Jun 7, 2025 | 11:56 PM
W205C43PFL's Avatar
Hi, Friend,
last Friday,
finally,
You are right!
Thank you.
Kaz. Hirasohzu.
Old Jun 8, 2025 | 07:46 AM
armbrust's Avatar
SLC 43 AMG
Smile Nice having a working Tach
Hi, Friend,
last Friday,
finally,
You are right!
Thank you.
Kaz. Hirasohzu.
Glad to hear that you got it fixed after over a year. Nice having the tach back.
Can you explain for the rest of us all the steps you had to do in order to get it to work? If so you may save someone else the year process you went through. This forum seems to be the only resource for someone with your type of problem.
Dave, Sarasota, Florida
Mercedes-Benz AGM SLC 43
