4matic 32amg?
I saw rcomparts c32 amg 4matic and just got me thinking!
Hope all is well!
4-Matic is a different trans. it won't fit directly, it needs to change some internal parts to fit it.....!!
ZAYED,,
I know all the suspension would have to be changed out up front to make it work but not sure if it is so much different with dimensions that it would be nearly impossible..
Internals what do you mean? Is it a whole different type of motor just for a 4matic transmission?
Thanks for the response!
also you have to change all front axles & steering knuckles & suspension & Engine oil pan which has a differ set-up wholes for axles shaft,,
motor is same, but the trans. has a differ set-up,,
it easier to do that converter with "E-W210 or C-W203 or S-W220", but SLK is soo diffecult & take a damn $$$$$ to do it.....!!
ZAYED,,
So basically I'd have to buy a donor vehicle with all the parts to transfer it over...
If only had that kind of money laying around... would be a fun drive if completed!
