SLK32 AMG (R170) 2001 - 2004: Discuss the SLK32 AMG.
Close to finding loud thunk! rear diff support
Old Jan 11, 2022 | 05:19 PM
om6424u's Avatar
GL350
So while accelerating I hear a loud thunk on my 2003 slk32
Took it to 3 shops they all think its top related or cant figure it out with a huge teardown
I have refreshed the Trans mount the Driveshaft flex disk and am ready to go to the rear and a wise MB guy said hey did you do the
Mercedes-Benz Differential Mount Kit
I was like no
Hes like did you check the
Corteco Subframe Mounting Kit; Rear of Rear Subframe
I was like no then hes like what about
Mercedes Differential Mount - Meyle
So lol lets say you were gonna try one of the above which one would you do first! its the passenger rear and its a popping sound with going forward and when going over driveways.
mbworld choose my destiny! :0
Old May 6, 2022 | 01:07 AM
Insty Gator's Avatar
'02 SLK32 AMG
I was like no
I would change my wheel bearing first!
02 SL32 AMG 110,000 miles started with a little click, going thru dips, then a little louder the longer I drove, no noise when first starting out. Thought it was differential noise,or Axle CV joint. Changed the axle w a 320 from junk yard, then the wheel bearing. I put the stock axle back in. I was told the axle was $1150 from the stealership and out of stock.320 won't fit they said. They could not tell me what was different other than the part number.Wheelbearing was only $60 after machine shop pressed it in.
