Engine cuts off!!
Also, it could have been a vaccum hose leak. They could never find the leak either, even though you could hear it-very clearly. Good luck.
Whilst I understand your situation is definitely not cool, I've clocked 5000miles on my 55 and it works exactly as it should. I've yet to have a single problem on it.
You do understand that when it comes to cars, you'll have those which when built have no problems, and then there's always one that ends up having a defective part.
Our cars are built out of over 10,000 different bits and pieces. If one of them is defective, it could cause all kinds of problems. I just hope you get it fixed, but ranting about it on a forum is not going to help much. You'll have to deal this out with the dealer and tell them to get their a$$ in gear.
Good luck
Good luck
Replaced fuel pump last week.The car drives much better and so far problem seems solved.
good luck.
I don't think you have actually identified the vehicle model you are talking about. Are we safe to assume it is a SLK 55? It does sound like the fuel pump to me also. Should be an easy fix, no problem. Let us know the outcome.
Just to clear things up my car is an amg 55, which I enjoy driving but this bad experience has dissapointed me greatly. I can accept the fact cars do and always will go wrong from time to time. But I can't accept Mercedes telling me there is no fault with the car because the computer says so
. Unless Mercedes believe it is normal for their cars to cut off whilst driving it can only be a fault
. I will inform the mechanics about the possibilty of there being a fault with the fuel pump. Thanks for the feedback.
Regards Happydude - NOT
You have a problem, the car is not performing up to your expectations, MB has to fix it. If they tell you there's no problem, they're just trying to circumvent/buy time/etc... they're not being very professional about this. Some dealers really are losers, wish I could pass you mine, I bet they'd get your car up and running in a jiffy.
