High Octane
Once you put some higher octane gas let the car idle for about 10-15mins and then put some miles on it and you should feel a difference. Worked for me!
I'll give it a try, thanks!
Dinko
I saw your post and had to ask here!
SLK55AMG, so you're saying it will adapt?
Dinko
The difference between 95 and 99RON fuel is pretty obvious so I'm sure you'll be able to feel the change when you try it...... most ECUs take upto 15 miles to adapt to a new octane rated fuel so don't expect an immediate change.
Kidding
Dinko
Dinko
Any before/after dyno pulls?
This is true on some cars but i doubt it on Mercedes. If Mercedes ECU can fully re-adapt because of the higher octane, then why Mercedes need to have 3-4 fuel and timing stages set-up in the ECU? Higher octane fuel allow you to run higher boost.
