SLK55 (R171) 2004 - 2010: SLK200K, SLK280, SLK350, SLK55, SLK55 Black Series
Upgrade the Speakers?
Old Nov 8, 2005 | 10:23 PM
NateDawg's Avatar
Has anyone upgraded the speaker system in their SLK? Every car and truck I've owned I've improved the sound system. However, the SLK is my first $60K+ relatively high end car. I have the command, 6 disc cd changer, sirius set-up with Harmon Kardon upgrade, but I haven't been impressed (I'm used to booming ). I'm obviously not going to change out the deck or anything, but I'd probably like to add some JL amps, a nice sub and perhaps replace the HK speakers. ANyone do this?
Old Nov 9, 2005 | 08:56 AM
Julien321's Avatar
06 SLK55 AMG Firemist/Blk
Producing a "booming" sound like in most hip hop music would not a true upgrade. The booming is usually a "hot spot" of over attenuated (4 to 6 dB higher) sounds at about the 100-150 Hz which is falsely perceived by the brain as very low frequencies (an audio illusion). The only way to achieve this would be by a larger diameter driver and this would probably require a trunk mount.
Old Nov 9, 2005 | 01:23 PM
Dozer42's Avatar
SLK55, Infiniti M45 Sport
And a trunk mount, I assume, would require a trunk.
Which we don't have.
(Ok, we can't afford to spare what little we do have) =)
Old Nov 9, 2005 | 01:42 PM
Bipasha493's Avatar
CLS 55 AMG
i'd replace all the stock speakers with MB Quart
Old Nov 9, 2005 | 01:44 PM
Bipasha493's Avatar
CLS 55 AMG
or if u really wanna go crazy try and fit some nice B&W's in there
Old Nov 9, 2005 | 02:30 PM
NateDawg's Avatar
I'm not thinking about putting in a two 12" subs . I was thinking more along the lines of replacing the stock speakers with MB Quart, JL Audio or similar type speakers. With respect to "boom", probably a JL 8" sub (which I think could fit in the truck with a custom box.
Anyone replace the stock speakers?
Old Nov 10, 2005 | 02:44 AM
Dozer42's Avatar
Bips would go for MB Quart, Ash would go for B&W. Personally I think Rani would lean more towards Dynaudios. We'll have to wait and see I guess.
