Questions questions.
but i have a few questions
1.) i know im in the break-in period so i was told not to go over 85miles and dun go over 4500rpm..
what happens if i went over it while i was in the break in period, is it THAT important to stick with the instructions?
2.) dealer said i go back for maintainace when the computer tells me to which is after 14000km......is that rite? cus i see some of u changing oil and stuff jsut after a few thousand on the odo.
help ? thank you in advance
AMG runs their engines pretty hard before placing them in their cars, so realistically, unless you have been redlining very often or hitting your limiter you should be ok.
2. You have a free welcome service before 3000 miles. you car will ask for service A when it needs it
In the UK, there is no 1000 mile service, its just a question of taking it easy, then the first service (Chargeable) is at around 10k miles. It can be service "A", "B" or "C" depending on your driving style, climate etc....
Hope this is helpful.
I don't think that running the car hard will hurt the car if there is nothing already mechanically wrong with it. But it will have an effect on the adaptation of the transmission. A rough transmission due to an interruption in adaptation is not a mechanical problem though. It can be corrected easily with a change in driving habits.
Your run-in period will be over soon enough. If you respect it, once you hit 1000 miles it will be like having a new car.
Have fun!
ps. He is right when he says that MB can tell everything you have done to your car by hooking it up to their analyzer - top speed, average speed, top rpm, average rpm, braking, everything . . . although, I have never heard of a dealer voiding a warranty because of going fast in the run-in period. What if you were in an emergency situation and you had to run the car hard to avoid an accident or get past a hazard - if you chose not to because of the run-in period MB could be liable. If it were really an issue MB would put a restrictor in the ECU that would govern the mph and rpm during the first 1000 miles. I think it is more precautionary than anything. Don't worry be happy!
