SLK55 (R171) 2004 - 2010: SLK200K, SLK280, SLK350, SLK55, SLK55 Black Series
Audio ??
Old May 2, 2006 | 04:05 PM
Derelique's Avatar
SLK55 AMG
Audio ??
Car didnt come with entertainment package and i need a disc changer, any suggestions? Dont want to spend a ton, mostly listen to engine. 6 disc changer in the glove box is what i was thinking...
Old May 3, 2006 | 02:06 AM
JBRhee's Avatar
Did you know our command unit can play DVD+-Rs? I stopped using my 6 cd changer once I found this out, I don't know if this info will even help u, but I just wanted to let u know in case you didn't. Also, the CD changer takes up the entire glove compartment and makes noises, i would much rather get a ipod kit installed.
Let us know what you decide to do, though.
Old May 3, 2006 | 04:16 AM
Shinigami's Avatar
SLK 55 AMG
The US spec glove compartment seems to be smaller then the Euro spec, so yes, the 6-disc changer in there takes up all the space. But it doesn't make noise on my car...
Do you have COMAND? If so, you can burn MP3 CD's and DVD's. You can have over 100hours of music on one DVD
Old May 8, 2006 | 11:38 AM
nishi's Avatar
2006 SLK55 AMG
can you insert DVDs in the front ? or would you have to put the MP3 DVD in the back?
Old May 8, 2006 | 01:01 PM
JBRhee's Avatar
It only works from the front. The one in the back is exclusively for the Navigation DVD - nothing else will work in there.
