SLK55 (R171) 2004 - 2010: SLK200K, SLK280, SLK350, SLK55, SLK55 Black Series
tires wearing out bad after installing lowering springs
Old May 6, 2008 | 04:55 PM
todd01clk's Avatar
s550
was wondering if anyone of one guys have that problem and does a camberkit help
Old May 6, 2008 | 05:07 PM
Ppower's Avatar
SLK55, Mustang 480hp, CBR600rr
take it you had the car re-aligned after installing the springs? Sometimes after lowering you need to adjust the alignment settings as it changes suspension geometry.
Where is your excessive wear at?
Old May 6, 2008 | 07:47 PM
firstslk55's Avatar
Think I have same problem. At big bumps the tires hit the sharp edge of the inside of the front fender. That the same with you? Anybody any ideas?
Old May 6, 2008 | 10:40 PM
dsb's Avatar
dsb
'06 slk55
Front tires are fine here. Rear tires are wearing a little more on the inside edge. However, SLK55 has never been easy on the rear tires anyway.
Here's a fix for the front... https://mbworld.org/forums/showthrea...t=front+fender
Old May 8, 2008 | 08:56 PM
duc&tlrsammy's Avatar
Benz and Beemers
Check your PM
Old May 8, 2008 | 10:31 PM
IIIMBPIII's Avatar
07 SLK55, 08 R32
This scares me cause im about to lower my car....
Old May 8, 2008 | 10:53 PM
ohlord's Avatar
Lowering
2 inches can take near perfect -.5 rear camber down to tire wearing -3 degrees.
front and rear camber kits from k-mac or custom coil overs can get it into spec.
Have fun after all it is only money
http://www.k1motorsport.com/mb/suspension.htm
k-mac also has a direct web site
lensolo and speedybenz may make a link bar also.
ohlord
Old May 29, 2008 | 02:33 AM
speedybenz's Avatar
AMG C43, 1999
Yes, I make a kit for the rear tires. See it at: www.speedybnz.com
The site also shows directions.
Jeff
Old May 29, 2008 | 11:20 PM
dsb's Avatar
dsb
'06 slk55
Jeff
The R171 is not listed. If you do make it, is the 350 and 55 model suspension the same? What is the cost?
Old May 30, 2008 | 12:30 PM
IIIMBPIII's Avatar
07 SLK55, 08 R32
Im a little confused here sorry. I just got my new 19s and I have H&R springs about to be installed with #1 spring pads what else are you saying I need to install to prevent negative things happening to my car?
