SLK55 (R171) 2004 - 2010: SLK200K, SLK280, SLK350, SLK55, SLK55 Black Series
Noise from the Seats
Old Jun 3, 2008 | 05:30 AM
lee7758's Avatar
Porsche 911 Carerra 4S
My SLK 55 always have some noise came out from the seat rail, anyone can help me with that, or anyone have the same problem?
Old Jun 3, 2008 | 06:25 AM
SLK55R's Avatar
'10 Porsche Turbo PDK, 500e, GL450
none here
whats the dealer say
Old Jun 4, 2008 | 03:45 AM
jeff_04's Avatar
1984 Honda Civic
We have the same problem lee7758. Good thing that you open up that situation. I hope that we solve are problem in this forum. But for now, I will read some auto related topics such as autopartswarehouse.com to get some information about car repairs.
Old Jun 4, 2008 | 05:38 AM
lee7758's Avatar
I went to the dealer twice, but the problem is still here!! They said they had already change all clips for the seat panel!! That noise really annoy me!!
Old Jun 4, 2008 | 10:25 AM
IIIMBPIII's Avatar
07 SLK55, 08 R32
What type of noise is it? I have a kinda squeaking noise sometimes but it was due to my seat being to far back.
Old Jun 4, 2008 | 08:41 PM
imducati's Avatar
slk55 2005; e320 2004 sport
I have the seat noise problem also, I have no idea where it is coming from.
Old Jun 5, 2008 | 01:37 AM
lee7758's Avatar
Yes, is that squeaking noise! Do you know how to fix that
Old Jun 10, 2008 | 09:51 AM
Shinigami's Avatar
SLK 55 AMG
There can be several reasons for noise... typically it's the seat belt buckle which is left sitting on the side of the seat and makes a clonking noise. This however is not a squeak...
Secondly, some early SLK's had the door lock bit inserted upside down, this too would make a clonking noise.
The seat may squeak if it's sitting too far back, it's rubbing against the rear wall.
The little belt buckle attachment clip may also squeak if it's rubbing against the side of the interior...
Does it make the squeaky noise if someone is sitting in the seat? If it still does it, it has to be something which is constantly rubbing against another slippery surface.
I just had my interior professionally cleaned with essential oils to re-hydrate the seat leather. This causes squeakiness for a few weeks since the seats are quite slippery from the oils. But this is probably not your case...
I guess you really need to find the exact location of the squeak, and if you know it's happening when someone is sitting in that seat, you could ask someone to take you on a drive and then start listening very carefully to where the noise comes from.
If all clips inside have been replaced, it might be the leather squeaking against the magnesium/plastic rear wall of the seat. A few rubber spacer might sort you out...
Old Jun 10, 2008 | 03:53 PM
lee7758's Avatar
Thank you so much, that helps me a lot, I will try to figure out where the noise came out! Thank you!
Old Jun 12, 2008 | 09:50 PM
lee7758's Avatar
I am going to bring my car to the dealer tomorrow! I will post out the result after the job is done! Hope the dealer can fix the seat problem for me!!
Old Jun 18, 2008 | 05:13 PM
lee7758's Avatar
Finally the dealer fix that sound for me! They said there are some brackets on the seat rail was lose! So they have change that part for me, and the nois is gone now!!
