Need expert tire/wheel advice
1. For those who upgraded to 19's, did you have to realign or adjust the suspension. The inside of my tires wear down way too fast. Do you get real rub on bad dips or bumps?
2. I was given the OEM wheel from an SL55 and I believe they are an inch wider. Will they still fit this car or will that extra inch on the front be a problem?
Thanks for any advice!
Mine is lowered 1 inch on 19s (8.5s front and 9.5s rear) using Toyo 235 front and 265 rear (very hard compound - fun to slide the car around with, but poor off the line traction). I do not have any rubbing at all. Keep in mind that not all tires are the same size; depending on the manufacturer some may be slightly larger or slightly smaller. For example, I run Yokohamas of the "same size" on my CLK, but they are slighly smaller (thinner side wall width) than the Toyos on my SLK.
I just ordred a slender 3mm hubcentric spacer for the rear SLK wheels to see if that looks better - if not, I will throw it back on ebay...
This forum has a lot of excellent information. Use the search function - it works pretty well.
Be sure to get lug bolts that fit properly. Check that the bolts you use extend the same amount into the hub as the original bolts (they should extend the same amount on the back side of the wheel.) I recommend getting the correct length bolts from your local Mercedes dealer. You may need to saw off some. A bolt that I got from excaliber .com sheared off, even using a torque wrench.
