Upset
i just changed all 4 rossos on my 06 car last october,(original set lasted me around 27000km since i got the car) and the new set up till now ive only driven it for 4 months which equals around less than 5000km max
so i went to do my service C today and the advisor said i need new rear tires. i was like r u f-ing kidding me, i just spent 2k on tires already last october, its new how can it wear off so quickly? then i got my car and went home to check, it was then i was shocked...... rear tires only had 20% left.... i check the front...they look like pretty new......
so this is really bothering me....how can it wear down SO much when ive driven it normally( no burnouts no nothing) original set lasted me over 20000km
the only POSSIBLE reasons i cna think of is:
alignment- but i got it done after i got fresh tires....maybe they did a bad job? but wouldnt i have known while i was driving it? maybe scrubbing?
wheels: i know the tire guys accidentally switch the original left and right the other way around....i asked but they say it doenst matter since its not directional.......
rubber: as u all know rear size for stock is 245, but i got 255 instead...thought i should be ok
so i have no idea wat or why its wearing off so badly....
godamit now i need to pay for new rear rubber with this bad economy on my back..... f*** my only enjoyment in life is failing me too
Thx 4 reading. any reasons why?
ps: mine is a stock 06 slk55 no mods watsoever
Definitely excessive tire wear. Are you guilty of aggressive driving? I have the same brand tires on my Mazda6 and they aren't wearing well. I had them rebalanced with no help. The tires (new) came with a set of Mazda wheels I purchased off eBay. I'll mark this brand off my list.
Definitely excessive tire wear. Are you guilty of aggressive driving? I have the same brand tires on my Mazda6 and they aren't wearing well. I had them rebalanced with no help. The tires (new) came with a set of Mazda wheels I purchased off eBay. I'll mark this brand off my list.no way...its winter and im just driving it normally, barley going half throttle
under 4000rpm
If you want a REAL performance tire, the absolute best choice without a doubt is Dunlap Direzza Z1 star specs, they are literally the #1 tire on the market and a relative bargain. Kuhmo MX is a great low cost alternative, both are world better than pilot sports which are honestly a joke.
Also the biggest problem is inner tire wear on lowered cars, only way to correct this is with adjustable camber arms, they will make your tires last much longer and give you improved straight line traction. Run close to zero as you can and your tires will last very long.
I think you need to take other things into consideration besides just tread life. Ex would be performance, noise, price etc.
Btw when I say performance tire I do not put them in the same category as R compound tires. Those I consider Ultra performance. If you want a REAL performance tire ... might I suggest Michelin pilot sport cups.
my wife's slk55 just got outfitted with those (245 front 265 rear on stock rims) and i know they will be good...
the oem pirellis on the 06 slk 55s are absolute garbage. she had 3 blisters on one of the fronts... come to think of it - never had good experience with any pirellis. expensive, non-reliable tire...
alex
few cars
http://www.nittotire.com/#index%2Etire%2Einvo
On the plus side the rear and front grip is much better. The rear tire no longer breaks loose under strong acceleration. The ride is also better and significantly quieter.
Has anyone else noticed the initial turn-in slowness with the sumitomos?
