Is there a spare tire for the SLK55?
If there's a spare tire, what is the size? Where is it; in the trunk or under it? Can I get rid off the spare tire and put a sub in there?
Why not use run flat tires or at least as an option? The new Corvette will use the new generation of ultra high performance run flat tires. Therefore there is no problem with performance issue.
By the way, what are you suppose to do with the 18" flat tire! Tie it down to the hood!
As to the 18" you take off, I guess you could fit it into the trunk with the top up and use string to keep the trunk lid from flapping until you got to the tire shop. In addition to spare string take along a large sized trash bag to slip the tire into.
Here's a thought.....When you go to change into your winter tires, how the hell will you be able to carry your set of 4 summer tires.....make 4 seperate trips
And to do that twice a year
D
You are right. I make sure I have strings and X-large garbage bags!
D
