SLK55 (R171) 2004 - 2010: SLK200K, SLK280, SLK350, SLK55, SLK55 Black Series
Whyissit?
Old Dec 12, 2004 | 03:37 PM
CP1's Avatar
CP1
SLK 55 AMG
Whyissit?
That when I put my roof down, the windows stay up. Also, I can remotely close the windows if the roof is up but I can not lower the windows. Is there a setting for this behavior?
Old Dec 12, 2004 | 06:44 PM
rguy's Avatar
If you continue to hold the roof down button then the windows should lower a few seconds after the top has finished lowering.
The top probably comes down first, right? Well, I guess Mercedes just didn't think of everything.
Old Dec 13, 2004 | 05:23 PM
CP1's Avatar
CP1
SLK 55 AMG
Well, for what it cost, they should have!
Old Dec 25, 2004 | 06:29 AM
mfd2112's Avatar
I noticed the windows stay up when you put the roof down with or without the remote. the windows do move down slightly for clearance, also they move down when you open the door. this is to reduce pressure when closing the doors. Its a big improvement along with many other improvements compared to the 04. I bet you'll want a porsche for your next car.
Old Dec 25, 2004 | 01:50 PM
Zman's Avatar
2005 SLK55
I actually prefer them to be up. If you need them to go down just press and release the down roof switch and the windows should go down.
Old Dec 26, 2004 | 09:51 AM
CP1's Avatar
CP1
SLK 55 AMG
When you lower the roof with the key fob there is no way to lower the windows. The windows will raise from the key fob, though.
Old Dec 26, 2004 | 04:32 PM
Zman's Avatar
2005 SLK55
Sorry, my bad. I missed the part about doing it with the keyfob.
Old Dec 26, 2004 | 09:21 PM
Julien321's Avatar
06 SLK55 AMG Firemist/Blk
Yes there is. After the roof is completely lowered release the unlock button on the fob. Now repress and hold the unlock button and the windows will lower.
Old Dec 27, 2004 | 12:30 PM
CP1's Avatar
CP1
SLK 55 AMG
Thanks, you're right! Of course by then my thumb is numb from holding down the fob button!
Old Dec 30, 2004 | 02:41 PM
Teufel's Avatar
2005 SLK55 2003 Acura MDX
Is there a way to lower all FOUR windows without lowering the top? So, the roof stays up and all FOUR windows go down.
Old Dec 30, 2004 | 07:39 PM
Julien321's Avatar
This is covered in the owners manual. Double tap the roof button back twice.
