SLR/C199/R199/Z199: SLR Production and Renntech
It's been asked a couple of times, but no real definitive answers have popped up. Can anyone fill in the missing coupe and roadster numbers:
Total number: 2114 or 2153 depending on source
Coupes -- ????
Roadsters -- ???
722 - 150
722s - 150
Sterling Moss - 75
Renntech perf PKG1 and LSD mods soon. Will report on results.
Coupes -- ????
Roadsters -- ???
722 - 150
722s - 150
Sterling Moss - 75
With lots of digging and various assumptions, this is where I've gotten so far in trying to sort out numbers:
ALL SLRS
Normal coupe - 1050
722 Coupe - 150
Normal roadster - 728
722S roadster - 150
Stirling Moss - 75
Total - 2153
USA SLRS
Normal coupe - 458
722 Coupe - 25
Normal roadster - 204
722S roadster - 25
Total - 712
Have no idea how close these numbers might be.
SLR on the way to Renntech today!
ALL SLRS
Normal coupe - 1050
722 Coupe - 150
722S roadster - 150
Stirling Moss - 75
Total - 2153
USA SLRS
Normal coupe - 458
722 Coupe - 25
722S roadster - 25
Total - 712
Now, SLR will go back to McLaren MSO in the UK to become ~700hp/~700tq SLR McLaren-McLaren Edition. SLR will receive:
- a new aero package resulting in 15% improvement in down force over the 722 Edition
- new suspension and dampers
- redesigned steering
- 10mm lower ride height
- lower weight
- redesigned body in line with latest McLaren designs including -- front and rear of SLR, new front and rear diffusers, new hood louvers, new side louvers, new louvers/ducting added above/behind front wheels ala 722GT, and new larger rear air brake
- new ceramic coated lightweight sports exhaust
- repaint
- Result: 1 of only 25 McLaren Editions to be built
- lower weight
- repaint
Congrats on taking the bold step to dramatically mod your SLR with the McL Edition changes. 1 of 25 will be the special of the already special. What RENNtech mods did you do that resulted in the 12% HP and 10% torque increases?
- Renntech pkg1 also comes with
-- two larger intercooler pumps
-- larger crankshaft pulley
-- new belt
-- tune of ECU
-- Handheld Tuner for going between stock and tuned if desired
- 100% LSD installed as well
-- new belt
-- tune of ECU
92 W124 500E, 93 W201 190E, 11 C207 E350, 05 W211 E55
The SLR is the reason I play the powerball lottery. Is there a recommended service interval for changing the Kompressor oil? For my E55 they are saying it is not necessary?
