Suggestions & Feedback Use this forum to post and discuss suggestions for both the MBworld.org Disucussion Forums and the the MBworld.org Website.
Notifications... replies, PM's, etc.
Old Aug 26, 2012 | 10:30 AM
gthal's Avatar
2012 C63 coupe
Hi,
On other forums (M3Post is the example I'm thinking of) there is a notification tab at the top of the forum page. When someone replies to one of your posts or posts in a thread you created, it tells you. This is a really useful feature as you can tell when someone has specifically responded to you when you can otherwise miss this.
Any chance this could be added?
Old Aug 31, 2012 | 08:25 AM
speedlimit's Avatar
Administrator Emeritus
Originally Posted by gthal
Hi,
Hi!
Thank you for the suggestion. You can check an option in your User Control Panel (under Options) to enable 'Pop Up' notification when a PM has been received. I'm not aware of any notification other than email notification for replies to subscribed threads. I'm assuming the feature is either in a newer version of VB or an installed Plug In. I'll run this by the moderators. Thanks.
Bob..
