FS: Carat Duchatalet Lowering kit for W124 300E, E320
Old Apr 28, 2008 | 04:46 PM
AMGDave's Avatar
300D, 500E, E420
This is a W124 lowering kit made by European Mercedes tuner Carat Duchatalet. They are similar to Lorinser, Brabus, etc but they are not as well known, and their products are quite rare in the USA. This kit is for a 300E sedan, but it may work fine on a coupe or cabriolet as well (with standard suspension). Includes front & rear springs, front struts, rear shocks, and the bolt kits for the struts & shocks.
This kit will lower the car approximately an inch, without sacrificing ride quality. I had this kit on my car for a couple of years and just recently swapped it out with a much stiffer setup from an E420 Sportline. You will need a proper Mercedes spring compressor to install the front springs.
The kit will NOT work on any station wagon models (300TE / 300TD), any V8 models (400E / 500E), or any model with self-leveling rear suspension (SLS).
$450 for everything you see in the photos below.
I also have the matching Carat Duchatalet wheels (17 x 8.0 ET38) for sale, a complete set of five (yes, five)... click here for a photo, email me for details...
Old Apr 29, 2008 | 09:53 AM
fal50's Avatar
1970 300SEL 6.3 , and a couple younger MB's.
Dave,
I'm interested in the wheels.
Please contact me off list fal "at" knology "dot" net
Old Apr 29, 2008 | 10:06 AM
AMGDave's Avatar
300D, 500E, E420
Email sent - let me know if you don't receive it.
Old Apr 29, 2008 | 10:12 AM
STLe320's Avatar
95 e320...sold the rest
Would you be willing to sell the springs separate from the shocks?
Old Apr 29, 2008 | 10:17 AM
AMGDave's Avatar
300D, 500E, E420
Nope, not unless the kit remains unsold for a month or two... then I'll consider separating the contents.
Old Jun 1, 2008 | 04:39 PM
Makahveli's Avatar
"88 300CE- First Year Production
So its neither stiffer or softer than stock? Who makes the shocks? I have a trunk spoiler by carat duchatelet on my car and having 8.5" wide 18" rims I can't lower my car too much. STL interested in Terra lowering springs if I go for these, the drop is even lower but with all the potholes the winter leaves along here looking cool isn't feeling so nice.
Old Jun 3, 2008 | 04:13 PM
AMGDave's Avatar
300D, 500E, E420
The kit is sold, and destined for an early 300E.
Makahveli, the Carat front springs are slightly thinner wire diameter than Sportline, with a tiny bit less coils & free length. The rears are similar. The approximate result is lower ride height but not a big change in stiffness. The shocks are Bilsteins, valved to Carat specs, but that's about all I know.
For your coupe, I'd lean towards the factory Sportline springs, since there are all different sizes available, allowing you to "tune" the height to where you want it. And yes, 18x8.5 is huge for a standard 124, you'll want to roll the fender lips as much as possible, if you haven't already!
As you said, slammed may look cool, but it's not very practical on the street. I'd aim for approx 14 inches from the center of the wheel to the bottom of the fender lip, front & rear, with a full tank of fuel. On my diesel I had to use a 400E Sportline spring up front to get it high enough!
BTW, photos of the Carat kit moved to this link. I can't edit the first post, sorry!
