WTB : lowering links for 2003 w215
03 w215,03 z350,08 kawi z1000 , 07 benelli tnt, 07 silverado crewcab z71
i am in need of lowering links for my 2003 cl500,i think the ones for the w220 fit,please let me know if you have a set
thank you
thank you
Well I bought the set because I was planning on getting a w220. But then I ended up buying a w215 same as yours instead.
So this lowering kit is just sitting at home waiting for a new owner. I can get you the exact specs if you would like.
yes,that would be very nice of you,where did you buy it from?does it have 4 or 3 links?
AMGTestDriverNJ ,still not sure if you want to let them go? cabbe i haven t heard from you...
guys let me know
bbbbbbbbbbbbbbbbuuuuuuuuuuuuuuummmmmmmmmmmmmmmmmmm ppppppppppp
guys let me know
You adjust your linkages to drop as much as you want.
In front you have to extend and in the rear you make it shorter.
Relation is 1:4 if you extend 1/4" in front the car will drop 1"
same for rear --- make it shorter 1/4" it will drop 1".
Front is easy you just unbolt the linkage and put 1/4" thick washer and put it back.
Rear --- you have to make your own linkage using 10/32 threaded rod and same size ball joint assembly.
PM me with your email and I will send you detailed instructions.
All this is not my idea --- I found it by searching through forums somebodyelse did this--
I used the instructions on my CL-500 an it works perfect. I lowered my car 1"
you r lucky,i m sure i could do it for the front ,but the rear looks a little complicated ,you r in chicago?
