219 211 230 amg rear 4 piston calipers
1999 c43
left 004 423 3598
right 004 423 3698
these will fit 219, 211, and 230 as per epc
to finish install on 211 or 219
brake pads 003 420 6220
rotors 2 @ 211 423 1012
to install on 230
rotors 2 @ 230 423 0912
you would also need bolts and sensor etc.
this is research i did you want to double check but i use epc a lot, all three models use the same backing plate/dust shields
left 230 420 1344
right 230 420 1444
these numbers may sub as per mercedes part system these are the numbers i found
$400 for the pair pm me or email me at ben.anderson1973@gmail.com
i live los angeles would prefer local pickup if serious i would ship i have paypal
right 004 423 3698
to install on 230
left 230 420 1344
right 230 420 1444
1999 c43
nope it wont correctly
the larger body cars use bigger 4 piston rear calipers and offset is different,
the 4 pistons that fit 203, 202, etc are from clk209 chassis late model and slk55 r171
these fit the cars i listed for sure, just bolt up add ventilated rotors part number i slupplied, and install brake pads
also if you did install 4 piston on the 203 you will have to trim the dust shield btw.
2006 mercedes benz C180k Avantgarde SE
Thank you for clearing that up.. the calipers from clk 63 and slk 55 are pretty hard to come by.. *sigh*..
I know that if we install the rear 4 pot calipers, we need to take out dust shield.. I guess these calipers of yours won't fit even if we do that.. ermm..
1999 c43
not sure from most of my research i dont think so, otherwise they would be on my c43 right now haha.
stick with what works, 209 is based off a 203 chassis so those will work, i have part numbers if you want them front and rear, two types the normal rotors and calipers, 4 piston rear, 6 piston front and the two piece rotors from the clk63 and the slk55 black series
yea..
maybe if you don't mind, you could pm me the part numbers. Appreciate that very much & thanks again for the info. Will put that in mind.
Good luck with your sale mate.
Zack
Zack
1999 c43
scratches
one has slight surface scratches if i get a chance i will post a close up picture.
they are pending sale right now, will know by monday
brakes
Mike
1999 c43
still for sale
they are still for sale, i will check to see if they fit the sl550 and the 09 e350 tonight here are close ups, one caliper has some small blemishes but shouldnt be that noticeable when installed
