FS: 05 SLK 350 BREMBO CALIPERS
Old Jul 8, 2010 | 03:24 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
Old Jul 25, 2010 | 04:55 PM
silverjimm's Avatar
04 Crossfire MB 5.0L M113 V8 6spd, 05 Bagged SRT6w/55K AMG V8 ,2016 C300 Sport
Still for sale?
Old Jul 25, 2010 | 05:02 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
Yup
Old Aug 24, 2010 | 05:10 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
....Make me an offer
Old Aug 24, 2010 | 09:17 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
SOLD!
Old Aug 31, 2010 | 09:34 PM
Wardsweb's Avatar
'11 SL550 - '08 ML350
Well the good news is the calipers got here. The bad news is while bead blasting the first one I found the bleeder valve has been sheared off at some point. You may not have notice, having never tried to install. I didn't even notice it when I took the "before" pictures or that it shows in your original pictures.
Anyone know where I can get a new bleeder valve. I still need to get the broken one out. Looks like some work bench time.
Old Aug 31, 2010 | 10:05 PM
  #32
silverjimm's Avatar
that is an easy fix. all the bleeders are the same on the Brembos.
can you post the part numbers on those bad boys!!
Old Aug 31, 2010 | 10:19 PM
  #33
Wardsweb's Avatar
VICTORY !
An easy out, a heat gun and some penetrating fluid. Only took about 10 minutes. You just have to be very careful with easy outs this small. If you break it off in the hole, the works difficulty raises exponentially.
Old Aug 31, 2010 | 10:33 PM
  #34
Wardsweb's Avatar
I'm not sure what numbers you want, so here are all of them.
Caliper one:
back - 20.7915.02
front - 20.7045.04
Caliper two:
back - 20.7915.01
front - 20.7045.03
all mounting arms are stamped 330
Old Sep 1, 2010 | 06:21 AM
  #35
dynomite05's Avatar
04 CLK 320 > CLK32K
Wow, good work!
Old Sep 1, 2010 | 11:56 AM
  #36
silverjimm's Avatar
Caliper one:
back - 20.7915.02
front - 20.7045.04
Caliper two:
back - 20.7915.01
front - 20.7045.03
Thanks thats perfect! Good work with removing the busted valve.
