FS: Assorted Mercedes engine & chassis special tools
300D, 500E, E420
I'm clearing out duplicate Mercedes special tools from my collection. All are SPX Tools unless otherwise noted, all are either brand new or used once, and in very good to mint condition (except the rear wheel carrier bushing tool, which is obviously worn).
1) Front crank seal installer for M119, M120, M112, M113 - $35 (also has 3mm inset position)
http://www.startekinfo.de/etools/con...2001%2014%2000
2) Front crank seal installer for OM60x, etc - $35 (does not have 3mm inset position)
http://www.startekinfo.de/etools/con...2000%2014%2000
3) Rear crank seal installer for most all 6-cyl engines - $150 (also has 3mm inset position)
http://www.startekinfo.de/etools/con...2008%2043%2000
4) New-style 124/129 Sportline rear subframe mount tool - $125 (also 170, 202, 208 chassis)
http://www.startekinfo.de/etools/con...2003%2043%2000
5) Steering box output (pitman arm) shaft seal installer - $35
http://www.startekinfo.de/etools/con...2001%2015%2000
6) Mini joint popper tool, for rear tie rods, also may work on other joints - $50
http://www.startekinfo.de/etools/con...2001%2033%2000
7) M119 chain tool with plastic case & instructions - $150 (custom aftermarket tool, super nice, very rare - new, never used!)
8) Rear wheel carrier joint tool - $50 (this is a funky no-name aftermarket tool - doesn't fit well, but works)
http://www.startekinfo.de/etools/con...2000%2043%2000
9) 400E/500E/R129 rear diff mount tool, for 66mm diameter bushings - $75
10) Standard W124/201 rear diff mount tool, for 46 mm diameter bushings - $75 (SirTools, with plastic case - Samstag sells this for $140)
11) W124 door alignment tools - SOLD (OE/dealer tools)
12) Radiator cap adapter for pressure tester, for older larger-diameter caps - $15 (OE/dealer tool)
Photos are below. Feel free to make offers on any or all. Free shipping in USA, PayPal is fine.
![Popcorn](https://mbworld.org/forums/images/smilies/popc1.gif)
#1:
![](http://www.w124performance.com/misc/ebay/tools4sale/tool1_M119_seal.jpg)
#2:
![](http://www.w124performance.com/misc/ebay/tools4sale/tool2_60X_seal.jpg)
#3:
![](http://www.w124performance.com/misc/ebay/tools4sale/tool3_rear_seal.jpg)
#4: - Click here for additional photos of the subframe tool & late-style bushing.
![](http://www.w124performance.com/misc/ebay/tools4sale/tool4a_subframe.jpg)
#5:
![](http://www.w124performance.com/misc/ebay/tools4sale/tool5a_steer_seal.jpg)
#6:
![](http://www.w124performance.com/misc/ebay/tools4sale/tool6_rear_tierod.jpg)
#7:
![](http://www.w124performance.com/misc/ebay/tools4sale/tool7_M119_chain.jpg)
#8:
![](http://www.w124performance.com/misc/ebay/tools4sale/tool8_wheel_carrier.jpg)
#9:
![](http://www.w124performance.com/misc/ebay/tools4sale/tool9_V8_diff_mount.jpg)
#10:
![](http://www.w124performance.com/misc/ebay/tools4sale/diff_mount.jpg)
#12:
#1:
#2:
#3:
#5:
#6:
#7:
#8:
#9:
#10:
#12:
![](http://www.w124performance.com/misc/ebay/tools4sale/rad_cap_adapter1.jpg)
300D, 500E, E420
Item numbers 1, 2, 3, 4, 5, 9, 10, 11 are all sold.
These are still available:
6 - Rear tie rod tool
7 - M119 chain tool
8 - Rear wheel carrier joint tool
12 - Radiator cap adapter tool
7 - M119 chain tool
300D, 500E, E420
Everything is gone except #12 - note that I made a typo, the adapter is for the old style larger-diameter tester, not larger caps. Oooops.
Also have Klann spring compressor for sale in a separate thread:
https://mbworld.org/forums/suspensio...r-springs.html
