Brembo/MB four piston calipers for C/CLK/SLK
Old Jan 6, 2011 | 10:09 AM
LantanaML320's Avatar
2004 Chrysler Crossfire
I have a set of four piston Brembo Calipers that are a direct bolt on for C/SLK/CLK/Crossfire. They will fit a 330mm that is 28mm thick. They are natural gray with white "Mercedes Benz" lettering. These can be painted silver (or any color) and AMG/Mercedes Benz/Brembo lettering is available on Ebay. I bought these from a guy that said they were CLK500 which uses a 345mm rotor but he was wrong. I was hoping to upgrade to 345 becuase I am doing a 330mm SLK55 rear rotor setup and want the front rotors to be larger than the rear. SLK32 rotors will not work with these as SLK32 uses a 32mm thick rotor.
Old Jan 6, 2011 | 10:38 AM
silverjimm's Avatar
04 Crossfire MB 5.0L M113 V8 6spd, 05 Bagged SRT6w/55K AMG V8 ,2016 C300 Sport
How much you looking to get for this setup?
Old Jan 6, 2011 | 10:42 AM
I am looking for $200 Here are pictures...
Old Jan 6, 2011 | 12:37 PM
You would need C350 Sport rotors with these calipers.
Old Jan 7, 2011 | 01:50 PM
BigBodyBenzC240's Avatar
...a panty dropper...
Were they in good working order? Couldnt you use the C32 rotors with there?
Old Jan 7, 2011 | 01:59 PM
They are in very good condition. C32 rotors are 345mm x 32mm and will not work. SLK32/SRT-6 use a 330mm x 32 rotor which will not work either as they are too thick. These calipers fit a 330mm x 28mm rotor as found on the C350 Sport. My Crossfire came with 300mm rotors and I noticed a nice improvement in the braking as well as very good looks. The four piston calipers with 330mm rotors gives a feeling of more authority when you brake. On the set I have on my car, I bead blasted them and painted AMG silver and added the AMG lettering which I found on Ebay. I get a lot of compliments since the Crossfire came with the ugly floating calipers as found on R170 SLK's and some C and CLK class cars. You need 17" wheels with this upgrade.
Old Mar 31, 2011 | 05:07 PM
bmartins's Avatar
w210 300td
Hello.
do this calipers fit my w210 300td 1997?
I want to upgrade it to 330mm.
To install 330mm rotors, which rotors should i fit?
Does the 345mm(C32/C55) fit there too?
Which should be the size of the rim for both cases?
Old Apr 4, 2011 | 07:00 PM
These calipers have been sold
