Mercedes Benz 722.6 Transmission
Old Jun 28, 2016 | 05:28 AM
James77's Avatar
2000 CLK430
Dear Sir,
My question is which one is backing plate in attached file name 1?
Which one are friction plates in the pack (this is about clutch clearance in attached file 2 - Figure 83.)? From #87 ~ #90 or #88~#89 or #88 or #89?
Thank you
Attached Thumbnails Mercedes Benz 722.6 Transmission-1.jpg   Mercedes Benz 722.6 Transmission-2.jpg
Old Aug 9, 2016 | 10:28 PM
exhaustgases's Avatar
LS400
In 1st picture the disks that are dark numbered 88 are frictions, the very bottom is a Bellville spring that absorbs shock. 87 is the backing plate and is all noted at the very bottom of the view. They are showing measuring the pack clearance between the snap ring and the upper portion of the backing plate after everything is assembled.
Old Aug 16, 2016 | 08:35 AM
CDM Motorsports's Avatar
Former Vendor of MBWorld
clk and e coupe
88 are the clutches, 89 are the steels.
