Cla 220 CDI all lights keeps on after removing battery
Old Dec 29, 2016 | 05:41 PM
Ramzicherni's Avatar
Cla cdi
I removed my battery and I puted again but most of the lights keeps on and all the counters not working ,also the gear monitor not showing anything .
The car running normaly .
Please I need urgent help thanks .
Old Dec 30, 2016 | 05:16 PM
Cla cdi
Originally Posted by Plutoe
Please explain in list format the steps you took to remove and install the starting battery?
thanks for your reply
Actually I did not start my car for 5 days I think something keeps on so battery died.
I removed the battery normally starting with negative first and then I charged and puted again positive and the negative .
The car start normally but all lights keeps on also rpm not working as its mentioned in the picture .
Old Dec 30, 2016 | 09:45 PM
Ussy123's Avatar
Mercedes A200 2015
Same problem as mine
This is the same problem as mine but my battery has been changed also cars been in dealership 4-5 times for this problem but cant seem to solve it.. Need help. Picture below shows it but all the lights are on now. And every warning is showing coming up.
Old Dec 31, 2016 | 03:36 AM
Cla cdi
Thanks for the update, your issues were\are caused by the low voltage and you will need a factory or equal diagnostic scanner to clear all the faults!!
thank you for the information
Do you think I can drive it safe ? The nearest dealer around 300 km to my place
Old Dec 31, 2016 | 03:38 AM
Cla cdi
did they scan it on the dealer ? What they told ? please advice me if you solve ur issue .
Old Dec 31, 2016 | 05:11 AM
Ussy123's Avatar
Mercedes A200 2015
Its been back 4-5 times but they cant sort it out. It just come back yestrday after a few hours of driving it back to normal, really angry now
