Brake Pad Wear Indicator Harness - W213 E53 Sedan
Old Mar 3, 2023 | 09:22 AM
W213E53's Avatar
2019 AMG E53
I hit a nasty pothole the other day to the passenger side front wheel, which not only blew the tire but also the brake pad wear sensor. After getting a new tire slapped on, I ordered a new Brake Pad Wear Sensor but when I went to put it in I noticed the bracket that bolts onto the caliper for the Brake Pad Wear Sensor Harness had sheered as well. I can't find a good part number on the harness itself, but also aren't having much luck with my local dealer over the phone in determining what I need. Everything in functioning properly, no more BRAKE indicator light on the dash etc. but I'd like to get a new harness on order and installed. Any help identifying the harness would be greatly appreciated.
Diagram below is courtesy of my dealership, and the bracket looks very much like 200 (where 210 bolts through) but I'm being told that the part is greyed out bc it doesn't apply to the W213 E53 Sedan. That only leaves 15 & 10 as candidates. The head of the harness where the Brake Pad Wear Sensor plugs in has a part# of A058-545-0428 which has led me nowhere. I can't find any other part #s on the harness... just a barcode that my barcode reader app read as 217965010742... again leads me nowhere thus far.
Old Mar 3, 2023 | 10:33 AM
edeleonmb's Avatar
Mercedes Benz
Hi, In the diagram # 15 is the harness that connects to the brake wear sensor. For the RH side part# is 213-540-22-69
See it here - https://parts.mbofcovington.com/oem-...sor-2135402269
Call me if you need more assistance 985-900-1129
File Type: pdf
File Type: pdf
Old Mar 3, 2023 | 10:56 AM
W213E53's Avatar
2019 AMG E53
Thanks so much for the help and the diagrams... just placed the order online.
Old Mar 3, 2023 | 11:31 AM
edeleonmb's Avatar
Mercedes Benz
I gave the incorrect information, the RH wheel speed sensor has the brake wear sensor harness made with it. The correct part number is 213-905-20-09. Very sorry for the confusion.
https://parts.mbofcovington.com/oem-...sor-2139052009
