2016 C300 4matic oil leak
Old Mar 1, 2025 | 05:32 PM
Oktim's Avatar
Hello,
recently I bought a used Mercedes-benz 2016 C300 4matic and today I saw that underneath the car the cover was loose so I decided to take it off and clean it. But then I saw that there is an oil leak.
I would like to ask for help identifying from which part is the oil leak and approximately how much does it cost to fix it ?
Also I have a small OBD diagnostic and i saw that there is a code P06DA(00).
Also i would like to add that i have no Check engine light and the car is not losing engine oil.
I have cleaned the part which had oil and i will check it again tomorrow
Thank you !
Old Mar 1, 2025 | 05:38 PM
W205C43PFL's Avatar
Originally Posted by Oktim
Hello,
Thank you !
For the code: https://mbworld.org/forums/gle-class...t-p06da00.html
As for the leak, get it addressed.
