V-Class 3 generations with first production year 1996...... V 230, V 280, V 200 CDI, V 220 CDI; Vito: Vito F 108 CDI, Vito F 110 CDI, Vito F 112 CDI, Vito F 113, Vito F 114; Marco Polo: Vito MP 108 CDI, Vito MP 110 CDI, Vito MP 112 CDI, Vito MP 113, Vito MP 114; Sprinter James Cook
2004 Vito CDI 115 Oil Specifications
Old Jun 18, 2011 | 06:25 AM
blacktie's Avatar
2004 Vito CDI 115
Hi there
Can anyone please help me with the oil specifications for a 2004 Vito CDI 115 wrt the
1) Engine
2) Gearbox
3) Diff
Any help will be greatly appreciated
Willie
Old Jul 16, 2011 | 06:35 PM
Malcolm@mill.me's Avatar
vito
merc spec 10w40 for engine in most conditions
sae 80/85 for manual gearbox
sae 75/80 for axles
multigrade hypoid 75/85 or 70/80 works for both gearbox and axles.
Oil spec is standard mineral oil.
semi synthetic is better than standard
fully synthetic is better than semi
It is a waste of effort and money to use fully synthetic in engines designed for mineral oils but semi synthetic can be well worth the extra.
Use 50% antifreeze solution all year - NOT methanol based except in high arctic type environments.
Use proper screenwas as due to long pipes detergent (washing up liquid) can go mouldy in the tubes (black gunge)
Front tyres often look flat so invest in a set of "indicating" valve caps
Fully Synthetic gear oils outperform standard gear oils by a wide margin.
"Magnetec" oils are superior in some engines but occassionaly people complain that they get "sluggish" after a few thousand miles... I've never had this problem.
Last edited by Malcolm@mill.me; Jul 16, 2011 at 06:38 PM. Reason: forgot part of it
