V-Class 3 generations with first production year 1996...... V 230, V 280, V 200 CDI, V 220 CDI; Vito: Vito F 108 CDI, Vito F 110 CDI, Vito F 112 CDI, Vito F 113, Vito F 114; Marco Polo: Vito MP 108 CDI, Vito MP 110 CDI, Vito MP 112 CDI, Vito MP 113, Vito MP 114; Sprinter James Cook
ESP problem Vito 115 2010
Old Jan 29, 2019 | 12:47 PM
Hsberger's Avatar
Vito 115 2010 and SLK 350 2008
Need help
Have a vito modell 115 year 2010 250000 km
The problem is the ESP does not work and the car goes into limp mode. Also warning lamp for low oil level comes on after a minute. Same times no ESP problem and it works normalt, same times ESP warning when i start the car but it gets worse and worse.
Checked fault codes in the ESP saying 51A5 CAN message from controll module faulty accelerator pedal position. Bought second hand pedal and installed it same code and ESP lamp and low oil warning. Do i have to calibrate it?
codes are:
2078-000
2306-000
2041-000
2040-000
2014-000
2062-000
2061-000
Also have
P0652 low volt sensor ref
P2453 diff preussare sensor diesel filter
Anyone have an idea?
Marcus
Old Jul 28, 2019 | 07:29 AM
Björn Risvall's Avatar
vito 111 2010
Hi, have you got any answer to your problem or does anyone know what to look for?
I have similar problems and the same lamps and error codes.
Old Jul 28, 2019 | 10:30 AM
Hsberger's Avatar
Yes changed the dpf sensor and one pipe to it then everything was working
Old Jul 28, 2019 | 03:20 PM
vito 111 2010
Is that what you mean?
Old Jul 28, 2019 | 06:56 PM
Hsberger's Avatar
Yes and check the pipes to it from the dpf so they are ok
Old Jun 23, 2024 | 04:32 AM
DIY_lambo's Avatar
Sprinter 2007
If I understand you correctly
are you saying that replacing your DPF sensor took care of the esp and accelerator pedal faults?
