V-Class 3 generations with first production year 1996...... V 230, V 280, V 200 CDI, V 220 CDI; Vito: Vito F 108 CDI, Vito F 110 CDI, Vito F 112 CDI, Vito F 113, Vito F 114; Marco Polo: Vito MP 108 CDI, Vito MP 110 CDI, Vito MP 112 CDI, Vito MP 113, Vito MP 114; Sprinter James Cook
W638 strange oil leak
Old 10-29-2023, 04:41 PM
Vclassv230's Avatar
V230 w638 and e350 blueefficiency
Hi All
i have a w638 v class v230 petrol.
had a very minor water leak so changed water pump at local garage.
it then started to leak oil on closer inspection it turns out the oil is leaking from one of the bolts that holds the water pump on! Strange!
anyway took it off again replaced gasket yet still oil is coming out and also mixing with water in the waterpump.
what is this all about why on earth would this bolt go into anything containing oil should just bolt onto the blockbut no this bolt gos into it right into it.
any ideas I would assume the same problem will occur on other models using the 2.3 petrol engine.
Any ideas anyone.
thanks
Sam
Quick Reply: W638 strange oil leak
