V-Class 3 generations with first production year 1996...... V 230, V 280, V 200 CDI, V 220 CDI; Vito: Vito F 108 CDI, Vito F 110 CDI, Vito F 112 CDI, Vito F 113, Vito F 114; Marco Polo: Vito MP 108 CDI, Vito MP 110 CDI, Vito MP 112 CDI, Vito MP 113, Vito MP 114; Sprinter James Cook
V250 W447 largest battery that can fit?
Old Nov 25, 2023 | 06:57 AM
Gsui's Avatar
G
Winter is already here and I love using my aux heater before starting a journey in the morning. Few times I get the Low battery message so I charge the battery overnight with my Ctek.
I plugged in my carly bluetooth dongy and it tells me the state of the battery is bad with 65% charge and 10% self discharge. I imagine from this numbers the battery lost almost 40% of its capacity?
Before I open up the passenger seat and see what kind of battery I have in there, is there somebody who installed a large capacity battery, let's say the largest capacity possible for the space under the seat?
Thank you in advance
Old Jan 26, 2026 | 04:17 AM
Xeo's Avatar
Xeo
V250d
Which solution you found for your problem?
Old Jan 26, 2026 | 04:25 AM
Gsui's Avatar
G
Hi there
I swapped the old battery for a OEM Varta same reference as the original battery from before.
I didn't find anything online of a compatible battery with larger capacity and the space below the passenger seat is very small.
Best regards
Old Jan 26, 2026 | 04:35 AM
Xeo's Avatar
Xeo
V250d
Thought to take advantage of the space on the left side front seat and retrofit an auxiliary leisure battery as in the Marco Polo's and hook on the auxiliary heater and the music system.
Old Jan 26, 2026 | 10:41 AM
Gsui's Avatar
G
Are we talking about the passenger or driver seat? Just to be sure, as I have LHD car.
The aux battery in the V250 is behind the front passenger seat, behind the rear panel but there is not a lot of space for more. The normal battery is in the side of the passenger seat. I haven't checked the same positions and if there are installations inside the drivers seat.
It could be that it will depend on the factory build and if they were included
