Vendor Group Buys Group purchases offered by our supporting vendors.
MB 2-piece light weight rotor (Gain more miles per gallon & hp at the wheels)
Old 03-14-2013, 04:05 PM
grane's Avatar
G350 Bluetec
5 mm lip
Warren,
It looks like at least the front brakes below have the 5 mm lip as the OP above stated. That might be good for measurement (and rusting) but I can't help but think it would lead to warping?
Grane
Originally Posted by RacingBrake
According to our research, the same front (360x36) and rear rotor (330x26) are good from 2001 up to 2006, until 2007 when the rotor sizes changed to 390x36 front and 360x26 rear which we already made available.
We have the discs and will make the hats for these earlier models, with 6-8 weeks lead-time.
Weight info:
Front OE 1pc = 37 lbs, RB 2pc = 22 lbs (estd.) Save 15 lbs/rotor
Rear: OE 1pc = 21 lbs, RB 2pc = 13.5 lbs (estd.) Save 7.5 lbs/rotor
Total weight waving per car (for 4 rotors) = 45 lbs
We also like to make our excellent street (ET) and track (XT) pads available to go with these two piece rotors to enhance the overall performance.
Old 03-21-2013, 12:34 PM
Former Vendor of MBWorld
RacingBrake's Avatar
CLS550
Originally Posted by grane
Warren,
Grane
The only reason I can think of is the extra margin for error. As the spindle, caliper, rotor, pad can come from different supplier to the motor company, this would assure after assembly the pad still stays inside the rotor than overhung outside the rotor.
They are more seen in European cars especially with Brembo calipers like MB, 5mm in diameter (2-3mm lip) over the actual pad swiping area is very common.
The rusty lip should have nothing to do in warping, but it can help to visualize the rotor wear w/o having to physically measure it.
Quick Reply: MB 2-piece light weight rotor (Gain more miles per gallon & hp at the wheels)
