Front tire lifting on launch with w210 e55!
w210 E55
Just kidding.........................now that I have your attention.............any w210 e55 owners have a problem with a popping noise in chasis on braking? Never noticed it for the past 4 years untill now. Any help would be appreciated.................then again..................I can just take it to the dealer and leave ya'll alone
![beat](https://mbworld.org/forums/images/smilies/beat.gif)
w210 E55
Originally Posted by amgdriven
Just kidding.........................now that I have your attention.............any w210 e55 owners have a problem with a popping noise in chasis on braking? Never noticed it for the past 4 years untill now. Any help would be appreciated.................then again..................I can just take it to the dealer and leave ya'll alone ![beat](https://mbworld.org/forums/images/smilies/beat.gif)
I take it none is going to respond to this thread.....so f#@* it.......OU SUCKS...GO TEXAS!
![Roll Eyes (Sarcastic)](https://mbworld.org/forums/images/smilies/rolleyes.gif)
1 Post
4 wheels
um first of all go OU. I have way too many friends and family at TX so I love to go against them.
Second, I would have the pads and rotors checked. They could be warped, cracked, or glazed over. Or there could be something wrong with a motor mount or suspension problem. I would have the dealer check it out ASAP.
w210 E55
Originally Posted by zoink
What popping sound? Elaborate please.... More like a metal hit a metal.... or like a bubble pop... or ???
1 Post
1989 Toyota Tercel EZ - dyno'd @ 70whp/77wtq
Looks like your engine mounting..... does it sound when the gear changes, especially in hard acceleration?
If you feel it in the steering wheel also while going through rough road, it may be your suspension / tie rod / CV joint. Checking CV joint is easy.... just park your car w/ the wheels turned... and if you see the rubber cover is full of grease.... your CV joint needs to be replaced.
I'd suggest you bring it to a local shop.... not dealers.... it'd cost you arm & leg just to check and have a mechanic check the area chappy and I suggest.
Good luck!
Good luck!
w210 E55
Good luck!
Good luck!
w210 E55
Originally Posted by Chappy
Any success with your issue?
![hammer](https://mbworld.org/forums/images/smilies/bonk.gif)
Dealership fixed it at no charge!
HEY...........THANKS FOR YOUR HELP AND CONCERN!
If I had a sister...................I would let her date you!
![naughty](https://mbworld.org/forums/images/smilies/naughty.gif)
