New to forum, I need help with wheel question
Old Sep 17, 2006 | 08:50 AM
papidos's Avatar
2002 E55 AMG
Last year my better half purchased a 2002 E55 AMG with Dunlop 9000 sport tires and 18" staggered Monoblock wheels that are OE for the car. My issue is that we live in Connecticut and these tires are terrible on any kind of snow accumulation. Even 1/4 inch makes just getting on the driveway an adventure. I'm looking for a decently priced and good quality set of wheels (new or used OEM or even aftermarket) for the E55 that I can put all season tires on for the winter. Any suggestions on Tires would also be appreciated. I'm confused about the offsets and which wheels actually fit the same as the OE wheels on a 2002 E55. All that offset stuff has me nuts.
PS: Sorry for the simple question. I'm sure this has been discussed 100 times already but since this is my first time on this forum it's new to me.
Old Sep 17, 2006 | 12:22 PM
MACHC5's Avatar
Veteran: Army
CLK63 Black, E350 Wagon, Supercharged Denali, Lotus Elise, Tesla Model 3 Dual-Motor.
TireRack is your answer....
Old Sep 17, 2006 | 01:28 PM
ROCKETW19's Avatar
06 EuroElites E55
you could always use the search feature up top in the banner. or you could just call a good wheel shop and they will know what you need.
Old Sep 17, 2006 | 10:16 PM
E55 KEV's Avatar
Veteran: Air Force
2024 GLE63s / 2016 GLE63s (traded) / 2016 E63s / 2002 E55
Since you are going to use the Dunlop 9000 in the good months you should consider a winter tire instead of an all season. You can also go with the same tire width front and rear on the winter tires because narrower tires make better winter setup. So consider 245/40/18 or 235/45/18 all around. There are also some, not many, but some 17" rims that will fit and you could use a 235/45/17 winter tire. The spare tire in the trunk is a 235/45/17 tire.
Caution. Tire Rack is the best source but they and everyone else will say a 245/40/18 tire on a 18x8.0 et35 and 18x8.5 et35 rim will fit up front. Depending on the tire having a rounded or broad shoulder a 245/40/18 tire may not work on a 18x8.0 et35 - I have tried. To use a 18x8.5 et35 rims you would have to use a 235/40/18 tire. These setups may fit up front on non AMG but I speculate the steering knuckle is different on W210 AMG's.
www.tirerack.com
www.discounttiredirect.com
Old Sep 17, 2006 | 10:43 PM
x-tian-230k's Avatar
CLK500/Range Rover HSE/E55 AMG/Bmw 328Xi coupe/BMW 4.8x/Bmw 335i/GS350/Audi S5/E350
You need a second set of rims and tires for the winter.. That is your best bet. E55's have too much power for the winter and all season tires.
Ct
