vibration question/tires?
i drove a 2001 E55 today that i'm very interested in. it was starmarked until six months ago and it's been well cared for. one item i noticed was that since the owner seldom drove the car, i think there may be dead spots on the new-ish tires. therefore, there's vibration at 45-50 miles/hr. this is a very different/subtle vibration, much different than front wheels being out of balanced. also, after the tires warm up, i think the vibration goes away.
my question is, will i need to get 4 new tires to get the car to drive properly or will this go away if the E55 become a daily driver? in other words, is the flat spot a permanent state on the tires in which case i will need to replace them...or can it be cured if the car gets driven regularly?
thx to all for responding.
Next, it may be an alignment issue as well. MBs are notorious w=for this vibration and it can definitely be worked out with some play. If that is all you noticed, then it must be clean.
Glenn
p.s. does the alignment actually go bad?
