Side Marker Bulb Replacement
Old Jan 17, 2007 | 07:51 AM
Kems E55's Avatar
Can anyone tell me exactly how to change the side marker bulbs on a 2001
E55? I haven't attempted it yet, but want to know "exactly" what to do when I replace them in a few days. Should be straightforward.......I hope.
Kems E55
Old Jan 17, 2007 | 11:35 AM
Vic55's Avatar
Administrator
Kems E55
Ken I am not 100% sure but your owners manual should tell you how to remove the reflector- I removed mine but it was years ago. I do believe you push the reflector forward (toward the front of the car) and then it pops out.
Old Jan 17, 2007 | 04:06 PM
sinbull's Avatar
E55 210
Side Marker Removal
Its really a breeze. First make sure your wheel is turned all the way over to gain access easily. There is a triangle opening where you can slip your finger in. Push the clip outwards. The whole assembly will pop out so that you can change the bulb. I found my bulb at the local pep boys.
Good Luck
