what are these "pads" how do i find out
Old Jul 1, 2007 | 01:55 PM
palmer3914's Avatar
2002 e55 w211 ....
Exclamation what are these "pads" how do i find out
hi guys not totally true that i dont know what they are.. as read a few links saying they are the pads at base of springs..... and they are different thickness's.....
But minebeing a euro e55 1999......... whAT pads would mine have in STANDARD??? and what pads would lower it? or raise it?
thanks again guys...
basically as i wish to lower mine.
Old Jul 1, 2007 | 05:02 PM
Eurosport's Avatar
monowiper
if you look at the pads closely the bottom side of them have dots on them showing what pad number you have.
example: you see 3 dots marked on the pad, you have #3 pad
depending on the market, also options sometimes, in stock form could come in different pads.
most common stock pads on w210 e55 is #2 front, #3 rear.
#1 pads are thinnest
#5 pads are thickest
do a search for exact measurements, i don't have that handy right now
Old Jul 1, 2007 | 06:10 PM
palmer3914's Avatar
2002 e55 w211 ....
thats great thankyou!!!!!!
so in all honesty what would happen if i simply got pad 1# all round???
would that cause any issues do you think??
Old Jul 1, 2007 | 10:14 PM
JamE55's Avatar
Out Of Control!
I heard Maxi pads are good? Is it true? lol
Old Jul 2, 2007 | 02:00 AM
Eurosport's Avatar
monowiper
no issues you'll be fine
Eurosport's Avatar
monowiper
Old Jul 2, 2007 | 10:26 AM
palmer3914's Avatar
2002 e55 w211 ....
right been to my local mercedes dealer and order some pads.... they listed 2-5 for front NO 1#s......... rear had 1-4.. so ordered 1#s
so mine will sit on pad2#s front and pad1#s rear????
am i wrong that i thought you could get front #1 pads?? as they simply said NO 2#s are lowest.
oh and 2#fronts are 9mm and go up in 4mm steps
same with rears 4mm steps
Old Jul 2, 2007 | 11:19 AM
SaMaS's Avatar
02 996 Turbo, 05 CLK55 AMG
ok here you go;
2 pads PART# A2103210184
2 pads PART# A2103250184
these are all #1 pads for front and rear... take a look what kind of pads you have in your car now... you can tell by removing the wheel and looking at the top of the spring you should be able to see bumps on the pads, 1 bump #1pads 2 bumps #2 pads and so on check just one side of the car otehr side should be the same... one more thing look how your car sits right now and if front sits higher then rear you might want to put #1 pads in front and #2 in back usulay car comes with #3 in back and #4 up front... good luck
Old Jul 2, 2007 | 02:45 PM
jimmydagreek's Avatar
2022 CLS450 AMG 4Matic
Spring pads for W210
Front:
#1 (5mm) = 210 321 01 84
#2 (9mm) = 210 321 02 84
#3 (13mm) = 210 321 03 84
#4 (17mm) = 210 321 04 84
#5 (21mm) = 210 321 05 84
Rear:
#1 (5mm) = 210 325 01 84
#2 (9mm) = 210 325 02 84
#3 (13mm) = 210 325 03 84
#4 (17mm) = 210 325 04 84
#5 (21mm) = 210 325 04 84
